I just got given a laptop with Vista Basic…I would like to wipe that OS and install XP Home or Pro…Whats the big deal with OEM?Does it have a key? I would wipe my laptop clean…
Any help would be great…
Thanks guys
Thanks guys
I just downloaded Xp Black
More Info…: Gamerman (Give Credit where credit is due) If you repost at least mention who made it.
XP Pro Corp SP2 with working Open License key, fully unnattended with
Black Transperant Glass them that uses no resources and doesn’t even run any extra Processes.
Updated with:
Ryans Update Pack 2.11
What’s Included Latest Version: 2.1.11
Windows XP Hotfixes
KB873339 - Vulnerability in HyperTerminal could allow code execution
KB884575 - Battery power may be drained more quickly than expected on Windows XP-based laptop
KB885836 - Vulnerability in WordPad could allow code execution
KB886677 - DBCS characters appear corrupted when browsing site using Shift-JIS encoding
KB887472 - Security update to Microsoft Windows Messenger
KB887606 - Microsoft XML Parser (MSXML) uses cached credentials incorrectly
KB888111 - Universal Audio Architecture High Definition Audio Class Driver Version 1.0a
KB889016 - Cannot obtain debug information about the resource objects of Application Verifier stop errors
KB889320 - Computer Browser service stops and Event ID 7023 is logged after Windows Firewall service disabled
KB889673 - DEP-enabled computer may unexpectedly quit after resuming from standby or hibernation
KB890830 - Malicious Software Removal Tool 1.30
KB892489 - Antivirus scan may increase the number of open handles for the svchost.exe process
KB893008 - PAL format digital video cameras are incorrectly detected as NTSC format digital video cameras
KB893756 - Vulnerability in Telephony service could allow remote code execution
KB893803 - Windows Installer 3.1 (v2)
KB894395 - IME Composition or Candidate window remains visible even after losing focus when using Japanese IME
KB895961 - Terminal Server Service update (From KB900325 Package)
KB896256 - A Windows XP SP2-based computer that has multiple processors exhibits decreased performance or unexpected behavior
KB896344 - Can’t transfer files and settings from computer running 32-bit Windows XP to computer running Windows XP x64
KB896358 - Vulnerability in HTML Help could allow remote code execution
KB896423 - Vulnerability in Print Spooler service could allow remote code execution
KB896428 - Vulnerability in Telnet client could allow information disclosure
KB896626 - Windows XP TV tuner program stops responding or displays corrupted video
KB897338 - New language locales for Windows XP Service Pack 2
KB897663 - Exception may not show up in the Windows Firewall GUI the exception is created by modifying the registry
KB898461 - Permanent copy of the Package Installer for Windows version 6.2.29.0
KB898543 - Cannot correctly install security fixes in Windows XP Starter Edition
KB899271 - Updated USB Video Class (UVC) driver for Windows XP
KB899409 - 20-second delay when trying to access a redirected folder by logging on to computer
KB899591 - Vulnerability in Remote Desktop Protocol could allow denial of service
KB900485 - 0x0000007E stop error in Windows XP SP2
KB901017 - Vulnerability in the Microsoft Collaboration Data Objects could allow code execution
KB901190 - Vulnerability in the Korean Input Method Editor (IME) could allow elevation of privilege
KB901214 - Vulnerability in Microsoft Color Management Module could allow remote code execution
KB902149 - FTP client may echo account information back to the screen
KB902845 - Computer stops responding during text-mode Setup when you try to install Windows XP
KB902853 - An unnecessary restore operation may be started on a RAID group when computer is put in hibernation
KB903234 - Update to optimize the way that the Volume Shadow Copy Service client accesses shadow copies
KB903250 - Song titles are copied to a recordable CD after cancelling a burn operation in Windows Media Player 10
KB904412 - SBP-2 device does not work when it is connected to a Windows XP SP2-based computer
KB905414 - Vulnerability in Network Connection Manager could allow denial of service
KB905749 - Vulnerability in Plug and Play could allow remote code execution and local elevation of privilege
KB906216 - The Dhtmled.ocx ActiveX control doesn’t work as expected after a program changes the Visible property of it
KB906569 - Update to add the Tools tab to the System Configuration utility in Windows XP Service Pack 2
KB906866 - 0x00000035 NO_MORE_IRP_STACK_LOCATIONS stop error when trying to log on to a domain
KB907865 - IPSec Policy Agent update
KB908519 - Vulnerability in embedded Web fonts could allow remote code execution
KB908531 - Vulnerability in Windows Explorer Could Lead to Remote Code Execution
KB908536 - Horizontal scroll bar used in forms may not respond to mouse controls or actions when using themes
KB909441 - In Control Panel, “Sounds and Audio Devices” does not correctly display the setting in “Speaker Setup” list
KB909520 - Software update for Base Smart Card Cryptographic Service Provider
KB909608 - Access violation when using /integrate switch to integrate KB900725 into Windows XP SP2 installation source files
KB909667 - Computer stops responding during standby or hibernation operations or trying to use the Shut Down command
KB910437 - Access violation error occurs when Windows Automatic Updates tries to download updates
KB911280 - Vulnerability in Routing and Remote Access could allow remote code execution
KB911562 - Vulnerability in Microsoft Data Access Components (MDAC) function could allow code execution
KB911564 - Vulnerability in Windows Media Player plug-in with non-Microsoft Internet browsers could allow remote code execution
KB911927 - Vulnerability in WebClient could allow remote code execution
KB911990 - Connection to the Sony Media Changer/Recorder is lost
KB912024 - Update Rollup 2 for eHome Infrared Receiver
KB912461 - Cannot obtain information about specific events when you program against the DVD Nav control in Windows XP
KB913296 - Jet 4.0 data engine update fixes issues that may occur
KB913580 - Vulnerability in Microsoft Distributed Transaction Coordinator could allow denial of service
KB913808 - The embedded resource version of the LIP MUI files is incorrect in Windows XP
KB914388 - Vulnerability in the DHCP Client Service could allow remote code execution
KB914440 - Network Diagnostics for Windows XP
KB914463 - WMI causes object access failure events when an SACL is applied to the HKEY_USERS registry subkey
KB914841 - Simplify the creation and maintenance of Internet Protocol security filters
KB914906 - “Unsupported State(2)” error message when a Windows XP Starter Edition-based computer continuously restarts
KB915378 - Update for Add New Hardware Control Panel
KB915865 - XmlLite update package for Windows XP Service Pack 2
KB916595 - 0x000000D1 DRIVER_IRQL_NOT_LESS_OR_EQUAL stop error on a Windows XP SP2 computer
KB917140 - Microsoft Application Compatibility Toolkit detailed log entries cannot be logged
KB917275 - Windows Rights Management Services for Windows XP SP2
KB917730 - You cannot create a network connection when you are starting a Windows XP SP2-based computer
KB918005 - Battery power may drain more quickly than you expect on a Windows XP SP2-based portable computer
KB918033 - Certain Windows dialog boxes may not retain the focus as expected
KB918118 - Vulnerability in Microsoft RichEdit could allow remote code execution
KB918334 - Error message when running a Win32 program that makes CreateFile function calls from a client computer to a server
KB918439 - Vulnerability in ART image rendering could allow remote code execution
KB918997 - Developers can’t create wireless client programs that manage wireless profiles and connections over the Wireless Zero Configuration service
KB919007 - Vulnerability in Pragmatic General Multicast (PGM) could result in remote code execution
KB920213 - Vulnerability in Microsoft Agent could allow remote code execution
KB920342 - Upgrade PNRP to PNRP version 2.0
KB920670 - Vulnerabilities in Microsoft Windows Hyperlink Object Library could allow remote code execution
KB920683 - Vulnerability in DNS resolution could allow remote code execution
KB920685 - Vulnerability in Indexing Service could allow cross-site scripting
KB920872 - Audio playback does not play file from correct position after pausing, and Stop error message randomly received when trying to play audio files
KB921401 - A non-paged pool memory leak occurs when you capture specific MIDI SYSEx messages in Windows XP
KB921411 - USB devices no longer work correctly after installing the Intel Chipset Software Installation Utility
KB922120 - Network Map in Windows Vista does not display computers that are running Windows XP
KB922582 - 0x80070002 error message when trying to update a Microsoft Windows-based computer
KB922668 - Windows XP COM+ Hotfix Rollup Package 14
KB922819 - Vulnerabilities in TCP/IP IPv6 could allow denial of service
KB923154 - EAP reauthentication may not occur and the Wireless Zero Configuration service may not work correctly when using a third-party application
KB923191 - Vulnerability in Windows Explorer could allow remote code execution
KB923232 - Computer using Intel dual-core processor stops responding when trying to resume from standby
KB923414 - Vulnerability in Server Service could allow denial of service
KB923980 - Vulnerability in Client Service could allow remote code execution
KB924191 - Vulnerabilities in Microsoft XML Core Services could allow remote code execution
KB924270 - Vulnerability in Workstation Service could allow remote code execution
KB924667 - Vulnerability in Microsoft Foundation Classes could allow for remote code execution
KB924941 - Update to resolve timing issues resulting in race conditions when using Bluetooth devices connected via USB
KB925398 - Vulnerability in Windows Media Player 6.4 could allow remote code execution
KB925623 - The Wmiprvse.exe process may experience a memory leak when WMI services and RPC services are extensively used
KB925720 - Windows CardSpace hotfix rollup package
KB925876 - Remote Desktop Connection 6.0 Client
KB925902 - Vulnerability in GDI could allow remote code execution
KB925922 - Computer restarts unexpectedly or 0x000000D1 stop error message received
KB926239 - Windows Media Player 10 may close unexpectedly
KB926255 - Vulnerability in Windows could allow elevation of privilege
KB926436 - Vulnerability in Microsoft OLE Dialog could allow remote code execution
KB926646 - Can’t increase the limit concurrent SMB command in the Windows XP Professional Server service
KB927544 - Can’t create an AVI larger than 512GB and can’t play an AVI larger than 800 GB using DirectX
KB927779 - Vulnerability in Microsoft Data Access Components could allow remote code execution
KB927802 - Vulnerability in Windows Image Acquisition Service could allow elevation of privilege
KB927880 - Can’t log on to a device that has both a blank user name and password using Internet Explorer 7
KB927891 - Access violation received when trying to install an update from Windows Update
KB928255 - Vulnerability in Windows Shell could allow elevation of privilege
KB929123 - Cumulative security update for Outlook Express (June, 2006)
KB929280 - Microsoft Management Console 3.0 does not correctly display 32-bit color snap-in icons
KB929969 - Vulnerability in Vector Markup Language could allow remote code execution
KB930178 - Vulnerability in Windows CSRSS could allow remote code execution
KB931125 - Microsoft Root Certificate Update (February 2007)
KB931192 - Users in a trusted external Kerberos realm cannot access resources from a Windows Server 2003-based forest
KB931261 - Vulnerability in UPnP could allow remote code execution
KB931784 - Vulnerability in the Windows kernel could allow elevation of privilege
KB931836 - February 2007 cumulative time zone update
KB932168 - Vulnerability in Microsoft Agent could allow remote code execution
KB932590 - Windows-based applications that use the TZ environment variable may not work as expected because of changes to DST
KB932597 - “Windows cannot find the network path” error message when trying to connect to a network resource
KB932662 - An access violation occurs in a program that uses the DirectShow DV Mux filter
KB933566 - Cumulative Security Update for Internet Explorer (June, 2007)
KB933876 - USN journal record contains an incorrect file name when moving a file
KB934161 - “Windows cannot calculate the effective permissions for User_Name” error when trying to view permissions for domain-migrated user account
KB934428 - Hotfix that adds support for SDHC cards that have a capacity of more than 4 GB
KB935192 - 0x00000044 stop error when resuming computer from hibernation after applying KB918005 hotfix
KB935214 - Access violation occurs when a program is automatically stopped
KB935448 - Certain third-party applications may not start, and “Illegal System DLL Relocation” error message received
KB935839 - Vulnerability in the Win32 API could allow remote code execution
KB935840 - Vulnerability in Schannel could allow remote code execution
KB935843 - 0x0000007F stop error when trying to print from computers that have KB925902 security update installed
KB936357 - Microcode update to improve the reliability of systems with Intel processors
Other Updates
Adobe Flash Player 9.0.45.0 ActiveX Control
Macrovision SafeDisc Driver Fix 4.00.060
Microsoft European Union Expansion Font Update 1.2
Microsoft Qfecheck 6.1.0.0
Microsoft Update 7.0.6000.374
Microsoft Web Folders 9.60.6715.0 (KB892211)
Microsoft Windows Script 5.6.8831 (Includes KB917344 Hotfix)
MSXML 4.0 SP2 (Includes KB927978 Hotfix)
MSXML 6.0 SP1
Registry Tweaks
DSO Exploit registry fix that Spybot Search & Destroy complains about
Hotfixes added. After ryans
KB939683 -› FIX: Update for Windows Media Player 11 for Windows XP
Download -› 549 KB (August 27, 2007)
Switches: KB939683.exe /q /n /z
KB939373 -› Vulnerability in Microsoft Internet Information Services Could Allow Remote Code Execution
Download -› 621 KB (July 9, 2007)
Switches: KB939373.exe /q /n /z
KB938829 -› Vulnerability in GDI Could Allow Remote Code Execution
Download -› 605 KB (August 14, 2007)
Switches: KB938829.exe /q /n /z
KB938828 -› Error message when the Explorer.exe process crashes on a Windows XP SP2-based computer: "STOP 0xc0000005"
Download -› 830 KB (July 24, 2007)
Switches: KB938828.exe /q /n /z
KB938127 -› Vulnerability in Vector Markup Language could allow remote code execution
Download -› 781 KB (August 13, 2007)
Switches: KB938127.exe /q /n /z
KB937143 -› Cumulative security update for Internet Explorer
Download -› 8.06 MB (August 14, 2007)
Switches: KB937143.exe /q /n /z
KB936782 -› Vulnerability in Windows Media Player Could Allow Remote Code Execution
Download -› 5.53 MB (August 14, 2006)
Switches: KB936782.exe /q /n /z
KB936021 -› Vulnerability in Microsoft XML Core Services Could Allow Remote Code Execution
Download -› 890 KB (August 14, 2006)
Switches: KB936021.exe /q /n /z
Vista Boot Screen addon by Ricktendo
IE 7 C
WMP 11 Tweaked
Mozilla FireFox 2.0.0.7
MSN Live 8.1.0178
OSX Leopard LaunchBar By GameMan
Mozilla Thunderbird 2.0.0.6
Ricks Custom Vista Sidebar Ported to XP
Extra Sidebar gadgets By Ricktendo
Extra Sidebar gadgets By Gamerman
Sidebar Settings By Gamerman vERSION 2
Programs included in Windows Post Installer:
Office 2007 Enterprise, Acrobat 8.0, Photoshop CS2, Diskeeper 2007, OO Defrag 8.5.178, WindowBlind 5.04 Enhanced plus many new themes, Open Office 2.10, TuneUp Utilities 2007 English, Norton partition Magic 8.05, Registry Mechanic 6.2, ISScript 10, Microsoft Java VM Build 3809, Sun Java 2 Version5.0.6 W/SP2, Azureus 2.5.00, IE 7 Final Activated, Firefox 2.01, THunderbird 1.5.0.9, Opera 9.02, WsFTP Pro, BS Player Pro 2.12.942, Klite Codec Pack 2.80, Shockwave/Flashplayers, Win DVD 8 Platinum, WM Player 11, Nod32 2.57, ZoneAlarm 6.5.737.2006 Pro, ZoneAlarm Internet Security Suite 7.0.279 Beta (ROCKS!!), Blindwrite 6.0.1.19 By eXperience, Nero 7.590A Premium Full, Nero 7.59 Lite, Poweriso 3.5, UltrIso 8.6.0.1936, DivX Create Bundle 6.4, Fraunhofer IIs MP3 Codec, Quicktime Alternative, Adaware SE Pro, Acrobat Reader, DVD DEcryptor, DVD2One, FlashFXP, GetRight, Magic Isomaker, PeerGuardian 2, VmWare 5.53, WinRAR, Winzip 10
[original attachment deleted after 2 years]
Hey Fidel Castro,
You should be able to install XP over your Vista system with your XP CD that you purchased using the product key that came with it.
So the product key for Vista Basic should work with OEM XP Pro/Home?
I’m not sure about that, man. I have heard that you can down-grade from Vista to XP. I will step back from this thread and let any windows expert offer opinions about this.
OEM should have a product key with it, usually it just means that it doesn’t come with a box and manual.
Big Q is why?
You got an OS.
If you want another, make a partition and install Linux.
It’s a laptop. Fuck XP and forget it existed. Move on.
Well for one I don’t like Vista at all, its a preference thing. I would like to replace it with a OEM OS but I don’t know enough about OS’s so I decided to ask here for help. But thank you herbie for your positive post.
Yeah OEM will come with a key. There is no difference in how the OS functions. OEM OS’s are just versions that usually come bundled with hardware. They don’t come in the fancy box. Both my computers are currently running on OEM XP installs. One is XP home and the other XP Media Center.
The only real difference of course is that the OEM will generally be much cheaper.
