Well, I got some help on how to fix the problem from phpBB. I need to run this code: [code]<?php
define(‘IN_PHPBB’, true);
$phpbb_root_path = ‘./’;
include($phpbb_root_path . ‘extension.inc’);
include($phpbb_root_path . ‘config.’.$phpEx);
include($phpbb_root_path . ‘includes/constants.’.$phpEx);
echo ‘
phpBB Template Error Fix
if( !defined(“PHPBB_INSTALLED”) )
echo ‘Error: phpBB is not Installed!’;
die;
if( ($dbms != ‘mysql’) && ($dbms != ‘mysql4’) )
echo ‘Error: This Fix only works with a MySQL Database’;
die;
$db = mysql_connect($dbhost,$dbuser,$dbpasswd);
if(!$db)
echo ‘Error: Could not connect to the MySQL Server’;
die;
$dbs = mysql_select_db($dbname);
if(!$dbs)
echo ‘Error: Could not select Database’;
die;
$query = “INSERT INTO “.THEMES_TABLE.” (themes_id, template_name, style_name, head_stylesheet, body_background, body_bgcolor, body_text, body_link, body_vlink, body_alink, body_hlink, tr_color1, tr_color2, tr_color3, tr_class1, tr_class2, tr_class3, th_color1, th_color2, th_color3, th_class1, th_class2, th_class3, td_color1, td_color2, td_color3, td_class1, td_class2, td_class3, fontface1, fontface2, fontface3, fontsize1, fontsize2, fontsize3, fontcolor1, fontcolor2, fontcolor3, span_class1, span_class2, span_class3) VALUES (NULL, ‘subSilver’, ‘subSilver’, ‘subSilver.css’, ‘’, ‘E5E5E5’, ‘000000’, ‘006699’, ‘5493B4’, ‘’, ‘DD6900’, ‘EFEFEF’, ‘DEE3E7’, ‘D1D7DC’, ‘’, ‘’, ‘’, ‘98AAB1’, ‘006699’, ‘FFFFFF’, ‘cellpic1.gif’, ‘cellpic3.gif’, ‘cellpic2.jpg’, ‘FAFAFA’, ‘FFFFFF’, ‘’, ‘row1’, ‘row2’, ‘’, ‘Verdana, Arial, Helvetica, sans-serif’, ‘Trebuchet MS’, ‘Courier, ‘Courier New’, sans-serif’, 10, 11, 12, ‘444444’, ‘006600’, ‘FFA34F’, ‘’, ‘’, ‘’)”;
$result = mysql_query($query,$db);
echo 'Inserting New Theme Record: ';
if(!$result)
echo ‘FAILED’;
die;
else
$theme_id = mysql_insert_id($db);
echo ‘SUCCESS’;
echo ‘
$query = “INSERT INTO “.THEMES_NAME_TABLE.” (themes_id, tr_color1_name, tr_color2_name, tr_color3_name, tr_class1_name, tr_class2_name, tr_class3_name, th_color1_name, th_color2_name, th_color3_name, th_class1_name, th_class2_name, th_class3_name, td_color1_name, td_color2_name, td_color3_name, td_class1_name, td_class2_name, td_class3_name, fontface1_name, fontface2_name, fontface3_name, fontsize1_name, fontsize2_name, fontsize3_name, fontcolor1_name, fontcolor2_name, fontcolor3_name, span_class1_name, span_class2_name, span_class3_name) VALUES (’”.$theme_id."’, ‘The lightest row colour’, ‘The medium row color’, ‘The darkest row colour’, ‘’, ‘’, ‘’, ‘Border round the whole page’, ‘Outer table border’, ‘Inner table border’, ‘Silver gradient picture’, ‘Blue gradient picture’, ‘Fade-out gradient on index’, ‘Background for quote boxes’, ‘All white areas’, ‘’, ‘Background for topic posts’, ‘2nd background for topic posts’, ‘’, ‘Main fonts’, ‘Additional topic title font’, ‘Form fonts’, ‘Smallest font size’, ‘Medium font size’, ‘Normal font size (post body etc)’, ‘Quote & copyright text’, ‘Code text colour’, ‘Main table header text colour’, ‘’, ‘’, ‘’)";
echo 'Inserting Theme Names For Record: ';
if(!$result)
echo ‘FAILED’;
else
if(mysql_affected_rows($db)==‘0’)
echo ‘NAMES DATA ALREADY EXISTS’;
else
echo ‘SUCCESS’;
echo ‘
$query = “UPDATE “.CONFIG_TABLE.” SET config_value = ‘1’ WHERE config_name = ‘override_user_style’ LIMIT 1”;
echo 'Updating Override User Style: ';
if(!$result)
echo ‘FAILED’;
else
echo ‘NOT UPDATED’;
else
echo ‘SUCCESS’;
echo ‘
$query = “UPDATE “.CONFIG_TABLE.” SET config_value = '”.$theme_id."’ WHERE config_name = ‘default_style’ LIMIT 1";
echo 'Changing Default Theme ID: ';
if(!$result)
echo ‘FAILED’;
else
echo ‘NOT CHANGED’;
else
echo ‘SUCCESS’;
echo ‘
Delete this File from your Server!
For any questions/problems about this script, please visit this Page
-phpBB Support Team’;
die;
?>[/code]
But how?
