[quote=“BTravenn”]
[quote=“Crazy Train”]
I believe that I may have answered your question earlier when I touched on projects like a second sheet of ice or a new pool for example. There is a fine line in there somewhere and it’s my opinion that with items like the airport improvement and a potential new emergency services building, that Council has not crossed it. Section 86 supports this.[/quote]
Section 86 is neutral and doesn’t support or oppose any particular issue being “decided” through an alternative approval process rather than a referendum. It is left as a discretion of the council. How they handle that discretion is a consideration that voters may take into account when they decide who to vote for.
I agree that there is a fine line between borrowing decisions where the electors are unlikely to have a problem, and those where they feel that they should be given a say through a referendum.
I don’t think the airport loan was particularly contentious because the airport will be making the payments on behalf of the City. There is some risk in that the City and ultimately its’ taxpayers are liable, but probably not a big one. That being said a referendum could have been held at the same time as the by-election.
Your examples of a second sheet of ice or a new pool, which may be viewed as “luxuries”, are good examples of where the electorate may disagree, so there should be a referendum.
The real issue here is the emergency services building. It would (will) be a major expense. The current lockup is below standards. Meanwhile, the fire department’s facilities are overdue for replacement (and everyone supports the fire department, right).
There is no clear or obvious way forward on this. There are alternative courses of action. That is another example of the kind of decision that should go to a referendum.
The current Mayor appears to be opposed to a referendum under any circumstances. There seems to be some underlying fear that the public will make the “wrong” decision. But we are ultimately talking about how much taxes citizens will pay to service debt on extraordinary items. I do not see how there can be any philosophical objection to voters having a say about expenditures that a subsequent council cannot undo.
If the electors turn down a loan bylaw, that would not be the end of the story. The City would have to go back to the drawing board and come up with something more likely to be acceptable. Maybe, for instance, a new fire hall would be acceptable as part of the package, or maybe not. There is nothing that says that a loan proposal cannot be revised and brought back, either at a second referendum or for alternative approval if there appears to be public support.
The other objection is the cost of a referendum, which is apparently about $10-15,000. There is a strange catch-22 there. That cost could have been reduced considerably if the council had agreed to voting machines, as recommended by then CFO Dan Rodin (in 2009 if I recall). But they rejected that because fewer election workers would be needed. But because voting is hence more costly a referendum is too costly.
Relative to the cost of any of these multi-million dollar projects a referendum is not very expensive. The Mayor and some councillors may have to forego their annual appearances in the 4th of July parade in Ketchikan.
As things turned out a decision was not made on the emergency services building. Instead, the Mayor and council kicked the can down the road. That negates the third objection to a referendum, which is the time that it takes. The City could have held several votes on the emergency building since they deferred the decision.
Eventually, though, the RCMP can and will upgrade the facility to meet current standards and send the City an invoice which it will have to pay under the municipal policing agreement (a copy is online). There will be no choice in the matter.
So instead of putting questions to the electors to make a decision one way or the other, or to provide guidance, the Mayor and council have passed on the decision to the federal government, and the taxpayers will pay accordingly without any say in the matter. Hopefully the next Mayor and council will correct this.[/quote]
You’re right, Council can elect to use section 86 and we now are judging them for it. I like their discretion in the discussed instances and I support what they’ve done. My votes on Nov 15 will reflect that.
You said "The real issue here is the emergency services building. It would (will) be a major expense. The current lockup is below standards. Meanwhile, the fire department’s facilities are overdue for replacement (and everyone supports the fire department, right).
There is no clear or obvious way forward on this. There are alternative courses of action. That is another example of the kind of decision that should go to a referendum."
By your statement you suggest that the expense is needed and the money will be spent but also suggest that it should go to referendum. Why? We all know that this building, in your words, is overdue for replacement and below standards, so why do we risk having the electorate say no when in the end it’s going to be done anyways?
