[quote=“yngwie_69”]I formated my comp and lost all my citytel gateway, Dns, and Ip address
i think theres another one to, This is for Dsl.
Can someone give me the numbers, Citytel is a pain in the ass to get a hold of on the phone.
For the IP i just need to know the first 3 sets of numbers[/quote]
PANIC! PANIC! OMG! CAN’T GET HOLD OF CITYWEST WHEN THEY’RE ON HOLIDAYS!!!:roll: lol
You don’t need to. If you got the OS (assuming you’re using XP) and network drivers installed and the ethernet cable plugged in, you should be able to use the internet. I did it once and I had no trouble whatsoever.
The ip address and gateway are unique - you can try giving yourself a private address and then pinging the range you think the gateway might have been (if you can remember) - if you get a response from something one hop away that’s probably your gateway - and then your ip address typically is one higher in the 4th octet. I think though you probably need to contact Citywest for the info - and then put a sticker on your dsl box with the info.
CityTel uses both Telus and Navigata - originally it was Navigata and Telus was added later. My adsl was one of the first given to residential customers and I still have a “Navigata” ip and gateway. I suspect that most (or all) of the traffic is routed over Telus and the Navigata is a redundant link now.
