Anyone know if there’s a way to tighten up a loose USB port? Moving the cable slightly will lose connectivity.
if its on a laptop your screwed, unless u have more then one, then you can use one of them gizmos which break out into 4
Laptop … see me bend over
[quote=“Soggy”]
Anyone know if there’s a way to tighten up a loose USB port? Moving the cable slightly will lose connectivity.[/quote]
First, make sure it’s actually the port, not the cable (by using some other USB device).
If it’s broken when you move it, then it’s probably a broken solder joint. If you know someone who is handy with that kind of stuff, it’s easy to fix. If you don’t know someone who can do this kind of thing, you can try the ghetto fix – super-glue it in place. But that’s not really a good solution.
