found this kicking aronud inside the case of a computer someone gave me. think its still good? can i just stick it in and see if it says my cmoputer now has 256 + 128 ?
one one of the stickers it says " XR-DIMM169/128SD-13" (thats not in one of the photos…)
whats the worst thing that could happen if i throw it in there ?
Taking for granted no physical damage and it fits the slot, you should be ok. If you put it in and you only get a black screen when you boot up, don’t panic, just remove it. If you still get a blank screen, then panic.
If your computer beeps when you boot up with the new RAM, get ready to defuse the bomb by looking at it and pressing the use key. Cut the blue wire.
Also, just have to say this, but make sure the computer is off before installing the new RAM. AND DON’T REMOVE THE “DO NOT REMOVE THIS STICKER” STICKER!
this is a cpu right? could anyone tell me which generation? arent there different formats of cpu? like… socket 7 and stuff? i remember a bit from way-back but i’m not sure.
what the hell hey, im gonna throw my old computers guts into the new ones case. if ya dont hear from me in a week, i probably broke everything and hope y’all have a good one. later
Look at the board that sucker came off. It’s probably an old P2B99 or early p3 Asus board. All the later slot370s were flat, fastest edge mounted chip I’ve seen was a Celeron 533.
You could probably sell that 128/133 chip for almost enough to get 256DDR these days… $50
Check out these: asrockamerica.com/Products/K7s41gx.htm
K7 all-in-one boards, should run you $69-$79, Sempron 2400 about $125. You can rebuild your old puppy for under $250
sweet, im back i guess. no quieter in the new case (which is what i was hoping) but the ram installed ok, and maybe with the sides on it will shut up a bit. thanks a lot for all the help and suggestions
