I am having problems with the font on my puter…how in the world do u change the size? I have gone thru the properties, and control panel but no luck!! Can someone advise me how to make the font size bigger. I can barely read some sites… pls and ty
Go to View beside favorites and then to text size
If you use firefox you can press ctrl ± to adjust the size of the text.
You could also make your monitor’s resolution bigger, or use “extra large” fonts… both of which can be changed from your Control Panel > Display and then the appearance, or settings tab. - if you use XP that is.
If you just want to change the fonts for webpages, do what the guys above said.
Hoorraaay thank you very much it worked!!
