For some reason i have to reset my bios everytime i start my comp. So Usually I leave it on 24/7.
If i dont reset my bios it frezes up at the mobo logo.
Help?
Help?
[quote=“yngwie_69”]For some reason i have to reset my bios everytime i start my comp. So Usually I leave it on 24/7.
Help?[/quote]
It could be the battery on the mobo. Have you recently done anything to it (the battery, that is)?
I havent touched the battery, i wouldnt think i would have to since the board is only a year old
year old doesnt mean any thing it could be a defective battery try a new battery then after that update the BIOS…
She’s right dude, like Metallica shouts…
“Battery”
And if you do decide to update your bios. B very carefull. Check out some transcripts from the show “Call for help TV” on techtv.com. There is an episode that he did on bios updates.
If you’re not comfortable with flashing the BIOS, get someone who knows how to do it for you. If you screw up, the board screws up. For the record, I also believe the battery is causing the problem you described. Open your case, write down the battery model number and start shopping.
I have fixed motherboards with bad bois’s when they flash them they screw em up. BUt only with the boards that the bios chip comes out of the board. : O )
Something this guy wouldn’ be able to do.
Only 5 bones, so ill see if that does the trick
yeah i see that. : O )
How are things going Landon ?
