MiG, crazy mike; its time to join the Jetsons and look at Home automation, I just ordered some gear to start, I’m doing some basic wiring in the house to make at all possible, best part with some software you can use voice commands to turn lights on and off, check the weather, time, turn the heat up or down, the possibilities are endless and some what not too expensive.
will post video in near future as i progress and experiment with it…
Strange coincidence. I just finished modifying an old parallel port cable to control a transistor which in turn controlled a 250volt relay. This is controlled by software on your computer and allows you to switch on and off any electric appliance. even do Pulse Width Modulation to control the brightness of lights, etc. I just found out I don’t have a parallel port on my computer Back to the drawing board…
YEAH! I ended up using my serial port instead. Found a pinout diagram and wrote a bit of code to switch on and off the the “request to send” pin. Pretty excited!
