Tried to go to thepiratebay.org and it said connection timed out. I tried to access the site thought a proxy site and it worked. Some US isp’s are starting to block sites like thepiratebay.org. Is Citywest stepping in line to do the same??
A couple of traceroutes:
From California:
[quote]bender:~# traceroute 194.71.107.15
traceroute to 194.71.107.15 (194.71.107.15), 30 hops max, 60 byte packets
1 172.16.95.218 (172.16.95.218) 0.076 ms 0.036 ms 0.030 ms
2 216.144.225.241 (216.144.225.241) 0.305 ms 0.334 ms 0.363 ms
3 96.44.180.246 (96.44.180.246) 0.426 ms 0.429 ms 0.459 ms
4 appliedops.net.any2ix.coresite.com (206.223.143.126) 11.324 ms 11.417 ms 11.391 ms
5 ge-0-0.cal-cr-0.srstubes.net (74.116.251.2) 9.114 ms 9.089 ms 9.056 ms
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *[/quote]
From Citywest:
[quote]$ traceroute 194.71.107.15
traceroute to 194.71.107.15 (194.71.107.15), 64 hops max, 40 byte packets
1 192.168.2.1 (192.168.2.1) 0.977 ms 0.302 ms 0.203 ms
2 24.244.72.1 (24.244.72.1) 14.187 ms 7.185 ms 18.326 ms
3 65.65.244.24.scpe.citywest.ca (24.244.65.65) 14.960 ms 13.248 ms 8.755 ms
4 1.65.244.24.scpe.citywest.ca (24.244.65.1) 15.000 ms 12.070 ms 42.844 ms
5 204.244.10.233 (204.244.10.233) 38.471 ms 41.154 ms 37.095 ms
6 ae1-0.vgs1.navigata.net (204.244.12.225) 37.803 ms 40.116 ms 36.284 ms
7 64.69.69.233 (64.69.69.233) 36.434 ms 34.566 ms 39.310 ms
8 10ge.xe-0-3-0.van-spenc-dis-1.peer1.net (216.187.88.54) 35.762 ms 36.063 ms 37.556 ms
9 10ge.xe-5-0-0.van-spenc-cor-1.peer1.net (216.187.89.205) 32.617 ms * 39.455 ms
10 oc48.so-2-0-0.sea-coloc-dis-1.peer1.net (216.187.88.214) 43.246 ms 42.663 ms 43.280 ms
11 six.appliedops.net (206.81.80.137) 66.552 ms 66.561 ms 62.741 ms
12 u221-098.appliedops.net (208.83.221.98) 75.914 ms 59.131 ms *
13 216.129.107.26 (216.129.107.26) 65.946 ms 76.871 ms 75.619 ms
14 ge-0-0.cal-cr-0.srstubes.net (74.116.251.2) 71.620 ms 67.519 ms 66.929 ms
15 * * *
16 * * *
17 * * *
18 * * *
[/quote]
Notice both are dropping at srstubes.net – that’s probably where the blocking is going on.
If you have a proxy that routes around that, then you can access it.
Nothing to do with Citywest.
That’s some rather important routing being done from a self-confessed small internet company that chose a name reflective of the joke “The internet is a series of tubes.” Smells of DOJ. lol
Their hosting:
Co-location package 1:
» 1U Rack server
» 512 gigabyte traffic
» Gigabit interface
» As many IPv4 addresses you need
» IPv6 stateless auto configuration
» Your own /64 IPv6 Network (optional)
» DMCA and copyright claims will be ignored
I was able to connect and i never use that site
AAAAARRRRRRRRRGGGGGGGHHHHHHHHHHHHH, matey!
I just tried connecting directly, that worked just fine. I don’t use piratebay.org.
*arez-bb.org for me, I can’t stand torrents for the life of me so I pay $10 a month to get a constant 700KB/s for every single download
No proxy needed. I don’t know why it wasn’t working the otherday, but now the address works no problem.
